Help-50amp rv plug to mep 002a
Tpoole
15
Alabama
Ground to chassis, neutral (sometimes labled white) to L0. X or black to L1 y or red to L3
Sent from my SM-G973U using Tapatalk
Thank you! What does the switches need to be set on? For this 220/110 , I am using a distribution spider box for now. When my shop is complete I'll use the 50amp rv cable to power the whole shop
Scoobyshep
2,247
Florida
Can you guide me on where to hook these wires for a 50 amp plug
That switch selects what the volt meter is connected to. In single phase mode you only need the 2 most clockwise positions. most clockwise is L3 to L0 and should read approx 120 the other is L1 to L3 and should read approx 240.
I am only seeing 3 conductors, there should be 4.
