Help decoding trailer ID code
boundstaffpress
La Junta, CO
Can any of you help me decipher what E2ITL means? I know that the other side indicates 634th Battalion Support Brigade.
The clues I have are these. There are two jerry can holders between the wheel wells and the tailgate. There are four holes (5/8) drilled into the floor that look like they attached something on metal skids. There is a large hole (1-1/2 to 2) in the middle just in front if the axle. I found a ground pole connection in the trailer.
Any help is appreciated.
bikeman
501
Ft. Bragg, NC
it would be 634th Brigade Support Battalion...
I'd say Echo Company 21st Trailer. probably tied to E21 as a prime mover. Echo Battery... should be for a Combined arms or... judging by the IL NG website, a Light or Straight Infantry Battalion.
juanprado
2,877
Metairie/La (N'awlins)
sounds like a m101 that had a generator in the bed. The large hole is on the passenger side for the fuel filler neck as it probably had a belly tank. Is there also a smaller hole next to it also maybe 1 inch (vent hose) ?
Is there a front splash shield underneath and 2 brackets in between the frame cross members?
boundstaffpress
La Junta, CO
It doesn't have a splash shield now. You are right abou tthe large hole being on the passenger side. I'll have to look tomorrow to see about a vent hole. There are four bolt holes closer to the from of the trailer that may have held a belly tank.
The trailer does have metal bows, I had read somewhere that all of the generator trailers had metal as opposed to wooden bows so that would fit with the generator trailer.
juanprado
2,877
the bolt holes in the side of the bed is for the fuel filler neck saddle bracket and there is also a fender brush guard. I will shoot some pics of mine so you can compare tomorrow.
The tank was under the trailer hanging off the frame.
boundstaffpress
La Junta, CO
Mine doesn't have anything like the filler neck shown, or holes to attach a tank that close to the axle. May just have to chalk it up to being a generic cargo trailer. Here are some pics of the inside of the bed. Something was bolted down for at least one repaint of the trailer.
