Help Identify This Light Tower
Memphisdoug
Memphis, MI
I am looking for help in identifying this light tower. It looks to be military but has no data plates anywhere. The generator is an Onan diesel. I believe the model is a 6.0 JE. I can't find any info on it either. I am trying to get it running but can't figure out if it is 12 volt or 24 volt. I also can't find a dipstick to check the oil? Any help would be greatly appreciated.
Crash_AF
Colorado Springs, CO
As I posted in your other thread (460CES) It's a TF-1 Flood Light set. Commonly used by the USAF until about 10 years ago when they started phasing them out for newer ones.
The 5KW ONAN is basically the same as a MEP002. I believe that it is governor frequency regulated though rather than manually. IIRC it is 12V. Look on the starter solenoid and it might have 12 or 24V on it.
I'll dig through my old AF stuff and see if I can find the CD that I had all of the manuals for commonly used power gen equipment on. IIRC it was on there.
Later,
Joe
Isaac-1
SW, Louisiana
The generator is an Onan J series, either DJB or DJE (DJE is the bored out version of the DJB and is visually identical), if your spec code is equal to or higher than AA (this is at the end of the full model number as it appears on dataplate, I am guessing something like 6.0DJE-3CM???????AA then it has the newer (post 1970's) YD series generator end, for reference on the YD series download a pdf of service manual 900-0184, google "Onan yd mixed 900-0184")
Ike
Memphisdoug
Memphis, MI
I have another question about this light tower. Since first posting, we have managed to break the glass in one of the reflectors when the trailer hit a bump in the road. The edge of the reflector is crimped around the glass to hold it in. When the glass broke, we also lost the bulb stabilizer that was in the reflector. Does anyone have one of these reflectors with the glass and stabilizer that they would like to sell me or have an idea where we might get one? Send me a PM and let me know.
We recently used the trailer at a scene where a tornado hit a campground with a lot of resultant damage. It really lit up the area!
Thanks for any help
