Help identifying parts
msitework
Lafayette Louisiana
Hey guys, I need help figuring out what is on the top of my motor. I have two m35a2s and bolted to the top of one engine is two cylindrical parts with wires and hoses, the other truck doesn't have them. They both run fine, what is it and do I need it? I tried looking at the TM and couldn't find them. I'll try to post a pic, thanks for the help.
Warthog
227
OKC, OK
That is fuel fired pre-start heater. Not need unless you are in a really cold area.
1,168
Fuel fired intake heater. Cold start system.
Your truck without it probably has an ether start kit upgrade.
No, you not need it.
If you looked through either of the parts TMs, you might have found it by simply looking at the pictures. Those TMs end with -P.
Also, either should be described (how to use them) in the -10TM(basic operators manual)
msitework
Lafayette Louisiana
I appreciate it guys, someone around here told me that's what makes the truck multifuel and I couldn't run alternative fuels without it. He's a gas mechanic and is clearly clueless. Thanks again.
steelandcanvas
85
Southwestern Idaho
Ask your questions here, we may give you a tough time about perusing the TM's and using the search feature, but the chances of getting smoke blown up your fanny will be alleviated.
