Help identifying this generator
thtrev2001
25
San Antonio, Tx
I picked up a couple of these generators and noticed they were a little different. I need help identifying what they were used for, how can I find this plug and can I convert it to a standard 110 v outlet plug. I put some fresh gas in it, topped off the oil and 2 pulls later it was running steady and strong. Thanks for any help.IMG_0400.jpgIMG_0397.jpgIMG_0401.jpg
Light in the Dark
5,130
MA
That panel does not appear to be the same as is shown in that file. Does it look original to the machine?
Bmxenbrett
29
I would make sure they produce power and the correct HZ before you go any further. If they do what you want i would just cut the wires behind that plug and install a normal 120v outlet. Will take some carefull cutting....or you could just install a outdoor electrical box and cover.
thtrev2001
25
San Antonio, Tx
The panel certainly looks original to the machine. I couldn't find any manual online that seems to represent this generator. I know that it was used by the DoD, but thats it. I'm not sure which agency etc.
I know I can probably just cut the wires, but I was really hoping to find out what it was used for. Thanks for your input
