Help ID'ing light/gen set
Isaac-1
50
SW, Louisiana
Can we get a picture of the generator, or a readable size picture of the Onan data plate?
Ike
p.s. I will guess it is a J series Onan of some type, most likely a DJB or DJE if it is diesel given the data plate appears to be mounted on a J series fan shroud, but again better photo would help. Maybe DJA if it is 2.25 KW
John S-B
1,048
Ostrander, Ohio
That doesn't look familiar to me, but I will say that military gen sets were always underated in their output to me. The 5KW diesels with the Onan engines were available as a 10KW gen set in the civilian world.
Isaac-1
50
SW, Louisiana
vertical parallel cylinders, or horizontal opposed cylinders?
Also can you read the fist 4 or 5 digits of the engine serial number, 2nd or 3rd space may be a B or C
model number should be at the top of the data plate in the 3rd photo, maybe a CCK, can't tell from the photo, format will be KW capacity followed by model number so something like 3.0CCK or 2.5CCK
