Help me identify this part...
kojo0513
Dallas Texas
Received my 87 6.5 yesterday afternoon. Doing some fluid flushes today and say this rusted out hole in the part behind the oil pan. What part is that? Transmission? Am I screwed?
Sorry I'm still trying to learn how to read the TMs...
Taken from the right side of the vehicle .
Here's the engine oil..
porkysplace
1,486
mid- michigan
Looks like the inspection cover for the flex plate and torque converter.
The TM's that end in -P are the parts TM's and have illustrations.
tennmogger
529
Greenback, TN
That triangular hole is probably just the drain hole for the cover and rust is minor. Nothing to worry about....unless the engine oil shown in the next picture is implied to have come out of that hole (joke) .
Bob
Retiredwarhorses
3,893
Brentwood, Calif
Yep...flex plate cover. To remove will require the starte and exhaust cross over pipe be removed...sometimes you can get the cross over off without dropping the starter....unless the flex plate is contacting the cover...just leave it.
And if you have never owned a diesel...the oil is soote black like that.
kojo0513
Dallas Texas
Haha phew. Thanks. Never owned a diesel. Closest I got was a 6.2 V8 Ford.
I assume this rig has been sitting around a lot for years. 13k miles. So doing a full flush.
porkysplace
1,486
mid- michigan
Never trust the odometer for correct mileage in a MV they swap gauges rather than repair them . The tell tale signs are wear on the rubber on the pedals.
kojo0513
Dallas Texas
In that case.. It's really old. I have no rubber.
Also, they seemed to have removed something on the left side of that photo. There was a wire running down to it and it's been snipped. Any clue?
kojo0513
Dallas Texas
They've cut the power cord with the male ends to the dimmer switch. Anyone know what size (12, 14, 16 gauge) that male plug is? Thinking about picking up a couple of the male plugs and calling it a day
