Help moving M818 from Torrington CT 18 miles to Woodbury CT
Sardo67
Western CT
Wearhouse clear out, M818 that was driven into the building 8-12 years ago and parked. Friend and I may buy it however, unsure if we can start it where it is now and if it won't run we can't easially move it. Other than $1,200 wrecker bill.
All the the tires are good and no dry rot, everything looks solid, flat tow with a bar would be the fastest and easiest way I think.
Heck, if someone has a bar and wants to help out we have a truck that can pull it.
Any pointers?
porkysplace
1,493
mid- michigan
How far are you moving it ? Sitting 8-12 years there could be issues with the brakes being rusted to the drums , wheel bearings needing service , if it has moved the grease could be rock hard . If by any chance it would start it is going to need a complete brake service . Do you know any excavating contractors with a low-boy that could move on a back haul or slow day ?
Sardo67
Western CT
I know plenty of guys that could tow it, all would want 4 figures or **** near it. This is my friends deal and he is on the cheap side and rather impulsive with his purchases. The building owner will probably let us get it for 2,000 or less for it if we can get it out by Saturday sincs it's right in front of the garage door and blocking the other 12-15 or so cars in. He bought a building packed full of stuff and a lot of junk.
I can can see the front axle seals have been leaking the time it's been sitting.
elkhtr
12
Stanwood, Wa.
1200.00 dollar wrecker bill sounds a bit high for eighteen miles.
Around here the semi wreckers run around 220.00 per hour for the wrecker, or 150.00 for a tractor and a landoll trailer.
Did he shop around?
swindad2
Franklin, KY
Wouldn't hurt to call a few towing services if you haven't already. Had my deuce hauled 180 miles on a low boy for $600. Highest quote I got was $830 from a towing company in Nashville, and they would've had to go 140 miles the wrong direction to get it.
porkysplace
1,493
mid- michigan
Having it prepped to tow would reduce costs also axles pulled (easier than driveshafts ) brakes freed up ect.
But $2000 for the truck $1200 to tow it = $3200 he should be able to find a running driving truck for a few hundred more.
Tow4
646
Orlando, FL
Less than $2k is a good price if you can get it moved reasonably.
M818 has air over hydraulic brakes so the service brakes should not be stuck to the drums. The only thing likely to be stuck is the parking brake if they have it on.
Check the oil levels in the axles, transfer case and then put the transfer case in neutral. Air the front tires up and pull it slowly to listen for noises. If everything looks good, tow it a couple of miles and stop and put your hand on the hubs and brake drums. If they are not hot you are OK. Keep in mind that if you hook up the service brakes to your tow vehicle, they could stick when they are applied (assuming they work). If you need to have the brakes working to tow it, I would trailer it or have a wrecker or large enough tow vehicle so you can stop it.
Good luck.
porkysplace
1,493
mid- michigan
Good luck.
If you pull the axles and front caps to flat tow it the only thing you have to worry about failing is the wheel bearings. The wheel bearings and brakes need to be torn down repaired/replace before being put on the road safely any how . There is no way to consider trusting hydraulic brakes that have sat for 8 to 12 years.
Sardo67
Western CT
We're going to tear into the 818 Friday and see what we come up with. Turns out a friend of ours will let us work on it at his house about a mile away so we aren't going to need low bed or elaborate trailer set up. But after a lot of research 2g is still too much. Going to need to talk a bit more.
