ODdave
- 38
- 0
- lansing michigan
Buy a DUKW next. Honestly, i bet it will run again, i dont think there will be as much sediment in vital areas as some think. To get LARGE amount of sediment you need flow, water working its way in through the breathers and slober tube is not going to permit much flow at all. With any luck vapor locks will form (except in the trans b/c it has to openings) and there will be minimal amounts of water entering the componants. The truck was not running so things where not up to temp so that should also help on the amount of vacum created by cooling the parts rapidly.
GIVE HER HE**, and let us know the outcome!
Good luck.
Good luck.
