- 10,859
- 745
- 113
- Front Royal, VA
Mounted jatonka's spin on oil filter adapters a while back. However, when I installed them, I misplaced the gaskets that go between the adapters and the engine block. I used a set of oddball gaskets that I had laying around and mooshed them into fit, and torqued the adapters down. Worked okay, a little seepage but not bad.
Today, started it up and oil all over the place. The gasket blew out and ripped, now I have nothing to act as a gasket.
I have a trip to make on Saturday morning with the deuce, I need a set of the appropriate gaskets ASAP. Can anyone point me to the right size gaskets at NAPA perhaps? Or if you have a spare set can you overnight them to me?
Perhaps jatonka can chime in with the right info? Please? Owe you a cigar!
