Help!! need replacement lunette for M101A1
MIhunter
South Dakota
I need some help guys. The threads on my lunette are dinged up and I cannot get the nut back on. I have been looking high and low for a replacement lunette but cannot find one for the correct size. I purchased one from Oshkosh, but it is way too big. My trailer is stuck into the garane until I find one.
DUG
Senior Chief/Moderator
73
Mesquite, NV
:ditto:
If it's REALLY messed up PM Hundy. He should have extras.
Scarecrow1
Florence , S.C.
If all else fails I saw one on e-bay today . It was at a very high price ....I think it would be cheaper to take it to a machine shop and have them rethread it .
MIhunter
South Dakota
It looks like someone smacked it a few times on the thread end to get it out. I managed to get the nut off, but now it will not go back on. As hard as it is to find a lunette nut, I don't want to risk cross threading it. The very first threads are smushed. They seem to be beyond clean up
wbdodgeiv
Roanoke, VA
If you really feel you can't fix it yourself, I would take it to your local machine shop and have them fix it. Shouldn't take much, most likely the end mushroomed a bit and some quick file work will get the nut strarted. You probably have just a couple bad threads, you could always carefully remove the first 2 threads with a file and see if the nut will start.
There are many things to try that would be a lot cheaper than buying a new one.
cbvet
20
Northwest (Knox) Indiana
It really shouldn't be that hard to repair. As mentioned above, judicious use of a file and/or a hacksaw blade should do the trick.
I know from experience, as I had to beat the crap out of mine to get it out.
