HELP! Rebuilt engne less than 700 miles. Engine started acting irregular, low vacuum reading, sooty spark plugs. Will no longer idle correctly.
Torisco
65
Bishop, California
Won the compression tester I bid on, with a ridiculously low bid, before being offered one by Ziggy 0. Sure appreciated the offer but was stuck with the bid I previously made for a tester.
Got my coil from Da Bella and got my distributor points rotor and condenser. Tester will arrive next week and I will again try to fix my engine problem and report what happens next week.
Torisco
65
Bishop, California
Had a family emergency and had to step away from my M43 problem. Am now back at it and family issue came out fine.
I tested the compression 1= 100, 2 =95, 3=97, 4=95, 5=98, 6=100.
I think compression is not a problem.
I pulled number one plug to check for spark. Grounded the plug body to the engine and cranked it over. I got a yellow spark (not a sharp blue spark) that seemed weak to me? Could the coil, points or condenser be the problem and fail after warming up? I have bought new replacement coil, points and condenser and think I will be changing them out.
The problem I have had from the start is a follows.
Starts up O.K.
Left to idle and warm up the engine will eventually slow up and die after warming up. It then will not restart unless you let it sit for quite a while.
The plugs all show black soot as though the fuel is not being completely burned. Replaced all plugs new. Rebuilt carburetor, checked for correct timing (it is within a degree or two).
Checked compression and all are within range.
Checked idle adjustment setting and fuel mixture setting. Gauged the carburetor float to spec when rebuilding carb. Idle screw was set at 3/4 turn from closed
Vacuum is around 17 - 18 (air filter and carburetor horn removed. Air lines to distributor from carburetor horn are disconnected)
Throttle advance or revving after initial start up responds as it should until the engine warms up and dies.
Does anyone have any ideas as to what could be causing this?
Torisco
65
Bishop, California
I hope you are not running the engine for long with the vent lines to the distributor disconnected.
Thank you for the info I had no idea about.
A Test run goes probably around 5-10 minutes max. at idle before the engine quits. The two air horn lines are connected at the distributor but the air cleaner and air horn assembly are and were off when I have test run the engine.
I read somewhere that if there is no air circulation to the distributor that the distributor cap trapped air area would become electrically charged causing misfires. Can you educate me on whether I should only test with the air lines to the horn and the horn itself connected. And would this lack of air circulation to the distributor lines cause my problems by that issue alone?
John Mc
361
Monkton, VT
I have no idea how long it takes for things in the distributor to build up to problem levels. I'll have to leave the actual education to someone who knows what they are talking about. A lot of people claim the vent lines are for cooling. However, a couple of very knowledgeable people have told me they are really to flush out the ionized air that builds up. If I recall correctly, it can cause misfires due to arcing and can also cause damage to the coil.
Take that with a grain of salt, however. I'm just repeating what I had heard.
I know when we swapped out the original carb on my 251 for a Weber 2 barrel carb, we had to come up with a new way to get flow through the vent lines. It doesn't take a lot of flow. I had thought about using the bubbler pump from an aquarium, but wasn't sure how well that would hold up to installation in the engine compartment.
Torisco
65
Bishop, California
I greatly appreciate what you have told me. After rebuilding the carburetor I have been running and testing the problem for, at least, half a dozen times for 5- 10 minutes without the air lines connected to anything (just hanging there). The original problem that started all of this appeared to be carburetor malfunction of over abundant fuel to the engine. I had gone 600-700 miles following all break in procedures since rebuild before this started with no problems. I did change the points in the distributor and was off by about 2-3 degrees on the timing since the rebuild and start of the problem. with all of this in mind...what would you make of me seeing a lack luster yellow spark from the number one piston spark plug versus the snappy blue spark I think I should be getting? And I do detect an intermittent miss when I am able to run the engine.
I will proceed to change the coil and replace the points and capacitor, set the timing to 2 degrees before TDC (approximate within 2 degrees) for number one piston, reinstall the carburetor horn and reconnect the distributor air lines. Only then will I try a test running of the engine again.
What do you think of this approach? and I will post the results on or before the 14th as I only have sunday to work on the old gal. Thanks again for assisting. It truly helps a lot.
JimC2
98
Collierville TN
I've always found the guys at Memphis Equipment to be candid and truthful. I don't think they would deliberately misinform anyone.
One of my airplanes had identical symptoms. Carb was loose on the intake manifold. Also, if you have a primer installed, check it for leaky o-ring (temporarily disconnect it and cap it off. I think you have a fuel/air problem, not an electrical issue.
chucky
19,291
TN .
Have you sprayed any either around the intake manifold while running to see if it changes idle rpm / float stuck in carb/ 1 tooth off on dist reinstall/spark plug wires crossed or bad/
ab705
205
33
Maine
There have been several good suggestions by others, so please pardon any repetition, but I have some questions/comments:
After replacing or cleaning the spark plugs, are they still sooty after running the engine? And if so, are ALL of the plugs equally sooty?
Do you know what your electric fuel pump output pressure is?
Is the electric fuel pump a positive displacement pump?
Is the electric fuel pump in series with the original fuel pump, and is it always turned on?
Have you checked the fuel line pressure at the carburetor? Depending on the types of fuel pumps used in series, there is the potential for an additive effect on pressure, and if the fuel pressure at the carburetor fuel inlet is too high, it might cause the float valve to shut off at an overly high fuel level in the bowl, or maybe even leak, either of which could cause an over-rich mixture and other symptoms.
Examples of some things to check: Make sure that the carburetor float action is free and doesn't bind anywhere. Also make sure that there is no pinhole or leak in the float itself that would allow gasoline to enter it and cause it to sink or ride too low in the bowl. Double-check the float level. Check the float valve itself for any damage to the needle or seat. Debris in the float valve can hold it open. Make sure the throttle plate isn't loose. Make sure all mating surfaces in the carburetor match up well, with no gaps, and that fasteners are properly tightened. Overtightening can warp carburetor body parts and cause leakage, etc., etc.
The ETW1 carburetor may appear to be a relatively simple carburetor, but it's actually a bit fussy to rebuild (not 'difficult' but it requires good attention to detail, as it's easy to make a mistake or overlook some operational detail). The governor can also be a bit of a challenge to adjust properly, and a special tool is recommended.
A detailed description and overhaul procedure for the ETW1 carburetor and governor can be found in TM9-1826A.
https://dn790009.ca.archive.org/0/items/TM9-1826A/TM9-1826A.pdf (see page 102).
Have you checked the resistance of each spark plug cable?
Have you checked the centrifugal advance for correct operation using a timing light?
Have you checked for play in the distributor shaft bushings? (That could affect the timing and dwell or cause missing.)
Have you checked for any cracks or carbon trails in the distributor cap?
It's possible for an ignition coil or condenser to develop intermittent performance due to heat or vibration, but if you have changed the coil and condenser with no change in symptoms, that problem would be less likely.
As others have mentioned, check for any possible vacuum leaks. The symptoms, such as a rough idle, hesitation, etc., can vary, but vacuum leaks in the intake manifold of a carbureted, non-computer-controlled engine (like yours) will usually will not cause an overly rich mixture, but would instead tend to cause a leaner mixture.
