- 7,426
- 2,538
- 113
- Interlachen Fl.
If you have checked every thing you should like Area 52 said heat air around intake. News paper big flame then have someone hit the switch.
If you have one of those military jumper cables, that would be fantastic.I live nearby, I can't fix the problem for you but could probably lend you a hand if needed.
It is, or should be, on the dash to the right of the steering column. There should also be a gauge to the left, next to the main power switch.I couldn't find the fuel hand pump mentioned in the forums. Where is it? I'll have to get some help getting the air out of my lines. I got about 10 gallons back in the tank. I'll put more in tomorrow.
