southdave
- 6
- 38
- ripley, oh/TDY Lordstown,Oh
Mr Stump, your following post was very informative. would the Man process contribute to the moreless deliquent nature of these engine to overreving?
I can think of two ways the MF engine might be more prone to over rev damage: First, because of its high compression ratio (22:1), it is a very long stroke engine. Second, because of the wide range of fuels used in the MF engines, and the large chamber cast into the top of the piston, the pistons are very strong, and quite heavy.Mr Stump, your following post was very informative. would the Man process contribute to the moreless deliquent nature of these engine to overreving?
I need a WEP throttle position for Mah Deuce! Booooo-Yaaaaahhh.The military has a long tradition of trading engine longevity for the ability to push the engine beyond its safety limits (if necessary). The old piston engine fighter planes had WEP (War Emergency Power) throttle positions that boosted the HP 10 or 15%, and added water injection to cool the combustion. To use WEP, you had to jam the throttle beyond its limit, which cut a safety wire (making it obvious that you used WEP). If you ever used WEP, your engine was scheduled for overhaul.
-Chuck
