Help with M1101 wheel bearing rebuild
NumberTwo
Peoria, AZ
Any help with parts and/or part numbers to do a full wheel hub rebuild job. I've looked around, but I'm not sure exactly what is needed and where to get the parts. Thanks in advance.
porkysplace
1,494
mid- michigan
cucvmule
collector of stuff
1,164
597
Crystal City Mo
Most time the numbers are on the seals. Unless the bearings are running without grease it is doubtful that they need replaced. Remove, clean and repack with quality wheel bearing grease.
And make sure that you tighten, then adjust bearing properly.
