HELP'''again
fletcher
kermit tx
ok guys its me again. looking for help with my deuce. the problem that just arised yesterday that has never happened before. i got called out las night to go pull a jeep out of being stuck. went to get my truck and it was hard to start (never done this before) it cranked, but took alot of turning. i went and pulled the jeep out and towed it home for him. i went to move my truck today and it was hard to start again. it finally cranked i drove it a few miles and it just died.... it finaly started again and went on down the road and died once again. i got it started and parked it.. the only thing i have noticed out of the ordinary is that my return fuel line connection is a little loose and has leaked a little. im not sure if this is the problem or not but i will try it first. i relocated my fuel tank to the bed about a year ago, i changed the filters, and i can hear the pump in the tank running. when it starts it seem to run fine for a bit and then just dies..... any ideas guy???
1,172
Check for fuel pressure at the secondaries with just the in tank pump running.
Any loose lines will allow air in the fuel system, causing hard starts
SixSpeed
Banned
1,107
Tampa, Florida
Sounds like an air leak. Any air leaks in the system (even VERY small ones) can cause problems as you describe. The hard starting is due to a loss of prime over time, and the dying is just fuel starvation. While the in-tank-pump can help combat SOME issues with air leaks, the injection pump just can't draw the fuel if there is a leak somewhere...
Edit: Awww...beat to the punch.
rosco
Delta Junction, Alaska
Your truck doesn't want to start/run, because it is not getting adequate fuel. Just because the "in tank" pump runs, doesn't mean it is pumping. If it runs/pumps, you will not get air in system, but have a leak. Fuel should gush out of bleeder screw at the primary/secondaries. If filters are contaminated, you will have the same symptoms. If fuel is contaminated, new filters can restrict fuel flow almost immediately.
