Hemmt Wheel Questions
shannondeese
High Springs Fl
I am picking up a set of Un-Cut HEMMT wheels on Mon and want some advice from the GURU's around here. I have access to a water jet machine and have a new set of centers being made right now. What I need to know is. Where do I cut on the stock HEMMT wheels to remove the old bolt pattern. Also when I install the new centers how are you making sure they are exactly center. And not going to wobble. Thanks.
ivbeenrokd
knoxville, tn.
My HEMTT wheels are at the machine shop right now getting worked up. He rough cut them out with a torch and then used a lathe to make a nice clean and true hole. also used the lathe to make the new plates. I can get some pics of the finished product when I pick them up this week.
Stalwart
33
Redmond, WA
A friend of mine made a step in both the center and wheel on a lathe. As I recall, he had about .008" runout after welding, WAY better than stock.
tonka tester
N.E. Il
what about having holes drilled in the new hub plate for the bolt pattern of the beadlock and sandwhiching it? you would still have to cut out the 10 lug pattern, but no welding required..
gimpyrobb
dumpsterlandingfromorbit!
27,785
750
Cincy Ohio
That would only work in a crappy mid-western state!
BWAAAAAAAAAAAAAAAAAAAHAHAHAHAHAHAHAHAHAHA.
Just kidding. I think it would allow for too much play, but maybe not. You would also have to find a BUNCH of longer studs to hold each rim together. Lots O money right there.
Edit: that wouldn't work as it would keep the air tight surfaces apart.
eldgenb
Spokane WA
no not between the two halves, behind them... the first thing that the studs would go through
you would still have to cut out the 10 lug pattern to get the hub through the center, all that idea eliminates is the need for welding which in my opinion has a much better looking finished product and a ton cheaper than sourcing longer wheel lock studs to hold it all together.
30
Honolulu,Hawaii
I am actually doing the same thing with the hemmt wheels I picked up. I going to knock out all the studs from the rim and will drive them through the 1/2" adapter plate that I am having water jet cut. After cutting I will bevel the holes for the lugs on the drill press. The water jet will also cut out the ten bolt pattern out from both halves of the hemmt rims. It will be a nice clean operation and the orginal studs are plenty long for the 1/2" adapter plate. With the three pieces of steel being sandwitched together and the hemmt rims O ring still sealing as designed I am not even going to weld them. I will add pictures after process.
