hemmt wheel torque specs
bobbed818
Wauchula, Florida
Getting ready to mount some 395's and was wondering if anyone knew the torque specs for the valve stem and the main bolts. Also should the o-ring be lubed to keep it from cracking?
Stalwart
33
Redmond, WA
Valve stem: 175-200 in-lbs
wheel bolt torque: Tough one, you need to almost read the TM 9-2320-279-20-2 Tech Manual Pt 2 to believe it!
Tighten all bolts no more than 1/4" at a time until halves meet, tighten to 75-100 lb-ft using a 12-6-3-9 o'clock pattern that shifts around till all are tight. Then tighten them in the same pattern to 450-500 lb-ft. Same torque value once again starting at 12 o'clock and one at a time clockwise. Repeat one more time at the same 450-500 lb-ft.
Now aren't you sorry you asked?
73m819
319
gainesville, ga.
seriously,do you really believe that the shop personal would followed that procedure, it will be more like put the air wrench to it, when it wont turn no more, its tight
Stalwart
33
Redmond, WA
If they were smart, they might do something close to it, those are BIG steel wheel halves that can run at 100+ psi! It isn't quite as bad as it seems but if you don't want a leak from the o-ring or a catastrophic failure you might want to do something that resembles it. That wheel is mounted to a tire that has a weight rating just shy of 15,000 lb. each that experience some pretty incredible stresses that no highway truck will ever see. If you're putting 'em on a deuce or 5 ton, taking 'em all down easy and torquing them to 200 lb-ft is probably fine, just not on a HEMTT in service.
I didn't see lubing the o-ring in the TM, I might have missed it. I'd just grease it a bit . . .
Look, that is what the TM said. Don't shoot the messenger, or next time why would I bother to spend 15 minutes getting what he asked for :roll:
bobbed818
Wauchula, Florida
Mounted two this afternoon. Went with the 3/4" pnuematic impact approach. Looks the same as the quarter turn way I'm sure. One leaks air pretty bad where the seam is welded on the lip. Guess I'll take it back apart tomorrow and figure out what the problem is. In case anyone is wondering, I weighed the tire and wheel before mounting. The wheel weighs 150lbs, 395 new weighs 210lbs. Simple math says heavy combo. I'm going to weigh an 11.00 tire and wheel combo tomorrow to see the difference.
Stalwart
33
Redmond, WA
I just had fun torquing the lugnuts today, that was fun, I was holding the extension for support and found my wife doesn't weigh quite enough to get the 600 lb-ft for the fronts with a 42" long torque wrench.
My suggestion: Use an impact, just a small one with a lower torque setting and bring all the bolts down together for the last little bit, the first part isn't the critical part. Or you could pick 4 bolts 90 degrees apart and bring them down in steps, once they touch bring the rest down to them and proceed.
bobbed818
Wauchula, Florida
I pulled them down little by little with the impact in a cross pattern until they were all snug then got them all tight with a 3/4" impact. I think I'll put a torque wrench on them just to see where they're at.
