HEMTT doors don't open from inside
bigmike
354
Dixon CA.
I'm looking at a HEMTT and noticed neither door opens from the inside latches. Outside only. Is there something I'm missing?
simp5782
Feo, Fuerte y Formal
9,343
Mason, TN
Unless the handles are broke. They have inside latches
Sent from my SM-G935P using Tapatalk
frank8003
4,984
Ft. Lauderdale, Florida
Did somebody reverse the latch mechanisms and how would one do that?
A 6x6 Deuce has combat door handle lock mechanisms so when riders
put it to combat lock and exit and close the door then that one or both those doors will never open again from the outside.
Is HEMTT like that, but reversed!?
bigmike
354
Dixon CA.
Hemtt has latches, not handles. They look just like the outside latches.
Sent from my SM-G900V using Tapatalk
Elideclan2
Barnstable,Ma
Take the panel off on the inside of the door.
There is a series of cables inside with adjusters.
Tighten the slack out of the loose cable.
This has happened on my m983(sold)
and my current m977. It's easy.
Jericho
69
Landaff NH
the "never open again" comment made my day LOL ,good humor, my grandson locked the doors in my m 109 and shut them ( 6 at the time ) was unable to open them again,, Was amazed when I reached thru the OPEN window to pull the handle up , JUST A BIG GOB SMACKED LOOK
JDToumanian
14
Phelan, CA
Hey Mike,
Are they loose or tight? My passenger's side inside latch is really tight, you'd think it can't be opened but it does if you put some muscle to it, and a little easier if you pull the door in slightly at the same time. If it's loose it may need the adjusting as mentioned above. I got new ones for mine, inside and out... Replacing them, cleaning and adjusting so the doors open and close easily, is on my huge HEMTT to-do list.
Jon
bigmike
354
Dixon CA.
The latches move easily and the latches move their full travel. Just nothing happens from the inside. You have to reach out the window down to the external latch on order for the door to open.
frank8003
4,984
There is a blonde joke in there someplace
