- 347
- 972
- 93
- Utah, Murray, United States
Great suggestion on those special lug nuts. Found them for 3.20 a piece online.This is a combat wheel
You don't want to use thimbles alone to hold a wheel on. Here is a special offset lugnut that can used with a HEMTT wheel on the front in lieu of longer studs:
10 LH and 10 RHGreat suggestion on those special lug nuts. Found them for 3.20 a piece online.
I have all my tires on HEMTT wheels. If you choose to run them on the rear the rear tires will be INSET just as much as the front tires will be OFFSET. So the front and rear will track several inches off of each other.Would they be worth it for the 4 rear hemtt rims?
For hemtt wheels on the rear I think offset lugnuts would be worth it.Would they be worth it for the 4 rear hemtt rims?
