HF radio in 1984 CUCV and RFI problem
Petersan
Wasilla. Alaska
Hello,
I am a new member here and I recently bought a CUCV from a friend here in Alaska. Its a typical 6.2 diesel and it runs great! I love the machine! However; as a life long Ham radio op I decided to install an HF mobile radio in the truck. When the engine is running a hear a hash sound over the receiver. Its really not too bad ( have had other mobile Hf systems in trucks where noise was sometimes 3 or 4 S units) This is much less then that, but its still loud enough to make hearing weak stations a chore. I believe it is caused by the charging system (maybe the alternator?) Have any of you folks ever had a similar issue? I will continue to unplug things and see what drops off the noise, But if its the charging system then that makes it a little harder.
Any help or ideas would be very much appreciated
73 Pete AL7PI Wasilla Alaska
tennmogger
529
Greenback, TN
Is your radio 12 or 24 volt? If 12 V, try switching which alternator/battery you are drawing the power from.
Wouldn't that risk grounding the midpoint of the 24 volt series string? Unless the radio has a floating ground on the neg/common power cable (which I have never seen). Be careful.
