Hi guys new guy with a couple of questions.
n2ojunkie
clio, mi
First hello to everyone I've been looking and reading a lot sense I've found this site, and would like to say I like it but I also hate it ;). I have a new way of spending money now. lol.
Second I picked up a m101a1 and a m116 with the gen set here in michigan and need help with what I need to tow it with. First I know I dont have the optimal truck but its what I have right now and its what I am going to use to get it home. I have a 2000 jeep tj. I've towed more than the the 1300lb i've read the m101 weights so I know how to be careful. It will be on back roads and going slow most of the way.
My question is what hitch do I need? I know what type but what size? I plan on going to tsc to get one so if anyone has any sugestions I would appreciate it. I did a search but I couldnt find anything specific on the size. I seen the m105 uses a different one so that got me wondering. Thanks.
James
wsucougarx
65
Washington State
Hitch=pintle. I got a hybrid pintle/ball combo. The ball size is 2 1/2 I believe and I can hook up a 1.5 ton M105A2 trailer and medium towbar to it. Depending on how low your truck is w/regard to the trailer lunette, I also got one of those variable height brackets that the pintle mounts to. This way I don't have to muscle the trailer down onto the pintle
n2ojunkie
clio, mi
OK so I can use a ball with the lock that comes over the top and locks down right? Right now my ball sits 22" off the ground. The jeeps lifted and I have 35" tires on it so it sits up a little. Will the 2 1/2" ball work on the m101? I thought I read they took a different size?
sloride66
Haymarket, VA
I believe wsucougarx was telling you to get this. I have the same thing on an '06 Jeep TJ w/ 4.10's, 33" tires and a 6 speed tranny. Pulls fine. Stopping distance is understandably increased.
n2ojunkie
clio, mi
OK I'm going out today and look for something to work. Neil what is the hook above that used for? When I think of a pintle hitch that's what I think of?
ojsdna744
Lapeer/Michigan
Are you goin to tow it full time with the TJ? Or just move it a time or two? It IS a bigger trailer for the TJ, especially with your Jeep lifted. I have moved my trailer with my Jeep, I'm also on 35 inch tires. It works, but it's much less than ideal.
If you just need it moved, I could help you if you'd like. I'm not far away, and would be happy to come move it for you with my CUCV.
If you'll be using it WITH the Jeep, just be careful not to load it too heavy. The tail can start to wag the dog if you know what I mean. :-D
n2ojunkie
clio, mi
Thanks but the m101 I plan on using a little more around town moving wood and stuff mostly short trips, but when I go upnorth hunting I was thinking of taking it with me. My cabin is around 250 mi straight up 75. I did tow a smaller camper this year when I went and it was too heavy for the jeep but I took it easy and did not have a problem. The m116 with the gen is more than likely a one time trip. That one is my sisters. We're still waiting on the euc to clear. If I need help I'll let you know as soon as I can. Thanks for the offer, not many boards with people like you on it anymore.
James
