- 319
- 14
- 18
- Gardnerville, NV
This measures 4.25" across, if that helps..
Pointman
Pointman
I had the same issue. I could feel the splines start to engage and the axle stopped turning, but the splines would not slide together. I started 'clocking' the spline engagement one at a time until they slid together easily. Conclusion, all splines are not created equal, have to find an alignment that fits. The splines probably have tight tolerances and are not worn enough to fit in all positions.Well... Last evenings attempt at inserting the front half shafts into the axle housing did not go well. It appears that the half shafts are not fully inserted in the axle housing, which makes it impossible to install the spindles in the knuckles.
At this point I am looking for ideas on how to get the half shafts fully inserted. I will try again this week as I would like to get this back off the jacks this weekend..
Pointman
unfortunately; in your last post, half your pics don't show. First four show as nothing but a link line that states "attachment xzy" with xyz being a numberThe Home Stretch....Lastly, ...
is this the seal that goes in the axle tube end and on the spindle on each side?Axle replacement seal list for M-1078
Part # Description Quantity per wheel
A-1205-D-2344 Axle Seal 2 1
