Higher Volume PS Pump?
Sharecropper
1,295
Paris KY
I already have cross-over steering, and now plan on installing ORD's high-steer and hydraulic assist unit which draws it's fluid power from the power steering pump. Since my pump is 31 years old, I considered replacing it to handle the extra load, and was wondering if there is a higher volume pump available. Anybody ever heard of this availability?
Thanks in advance for comments.
richingalveston
122
galveston/Texas
PSC motor sports
The parts ORD sells for pumps, gear boxes and slave cylinders are from PSC
you can get the high volume pump from ORD or go direct to www.pscmotorsports.com
The pump requires a remote reservoir which is needed because you need more fluid volume also. I had to mount the pump and then run the hose to the reservoir through the right side alt. belt. I will have to drain the reservoir and remove hose to change the belt but that is not a big issue. I can get pics of mine at some point but I am away from my truck working right now.
I have the cross over, high steer, with psc hydro system and my truck steers with my pinky finger at all times.
