Hitch-Bolster trailer
TadB
Loganville, GA
Quick question, I won a bolster trailer at Eastover Several weeks ago. I'm not real keen on the idea of pulling atrailer 175 miles that I have never seen(except in pictures). They do not have a lift there to set it on my gooseneck. My only other option is to disconnect from the gooseneck and back the bolster trailer on it, then reconnect. My question is, is will a civilian pintle work with the ring on the bolster trailer? Or is it too small?
Nonotagain
41
Parkville, MD
The M796 bolster trailer weighs 5900 lbs. Unless you have a way to hook up the brakes, I wouldn't tow it on its own wheels. Make sure to release the two parking brake handles.
The trailer moves rather easily, so you shouldn't have a problem moving it onto your gooseneck.
You need a 12,000 lb rated pintle for a lunette that is 3 1/2" in diameter. A Valley 2 5/16" combo ball/pintle is too small for the ring to drop over.
TadB
Loganville, GA
Im going to put it on the gooseneck. I just didnt know if the ring on the bolster trailer was too large for a civy pintle(for when I'm backing it onto the gooseneck). Only reason I ask is I know the pintle on my five ton is too large for the pintle on my 30 ton civy tag trailer. So I did'nt know if it would work the other way
NEIOWA
127
NE IOWA
If you're worried, jack it up and see if the wheels turn freely. Or plan B pull it for a mile and check if hubs are hot. If OK, and you drive with a lick of sense, pull it home. Not rocket science.
Most Army trailers get little use (or maintenance). + or - depends on your point of view.
TadB
Loganville, GA
I'm not worried. Its only going to be moved far anough for me to back it up on my gooseneck. I'm going to haul it home. Just wanted to make sure i had the right hitch to hool up to it(to put it on the trailer).
rosco
30
Delta Junction, Alaska
Your civi pintle will work on the bolster. Its too heavy for even a 1 ton! You can back it on your goosenect, if necessary, but they will often be able to help you load it. I have even drug trailers up on my trailer with a come-along, frontwards, and backwards. If you back it on the trailer, you might have a problem when you get to the landing gear on the tongue. It hangs down quite a ways. You might just un-pin it, when you get to it, and leave the tongue rest on the deck. Throw the landing gear into your pick up for the ride home. Good Luck
benand117
cuyahoga falls, oh
How is the bolster too heavy for a one ton, but it isn't too heavy to add it to a trailer and tow that. My 1992 half ton chevy is rated to tow 7000lbs. I have towed a lot of cars on a tow dolly with it that weigh 4000lbs. The dolly has no brakes and it also has no tongue weight. If the bolster weighs 4800lbs and it's empty, as long as i had a pintle that was large enough, I would pull it home with anything half ton and up.
TadB
Loganville, GA
Since getting the bolster traler home I Have pulled it several times (unloaded) with my F250. I pull it behind the deuce picking up logs for my Woodmizer. I dont think I would be comfortable pulling it with a 3/4 ton loaded!
