HMMWV 4-man Soft Slant Back Feedback and Discussion
Bulldogger
774
Quantico VA
Some people have asked what a frame that more closely resembles the military slant back with the humped rear would look like. In response, I'm working on a new frame that will be a totally new design for the frame and cover. I welcome feedback on this idea. It is a bit taller on the rear end than the military and Plan B hard covers. This is because of the limitations of my tubing bender. If I can find a way to economically bend tighter and give a shorter "tail", I'll try it. Ideas welcomed. The frame is much wider in the center, to allow full bed access. This makes me think cross bars are needed for support. These cross bars will be in the way of getting into the bed, so I am looking for solutions. One I will try soon is to permanently connect one half of the tee clamp and use a wing nut to make the other half removable.
BDGR
Bulldogger
774
Quantico VA
I'd appreciate feedback on this new look. This is a rough cover for the "humpy" frame. One is in 1000D Cordura nylon (that soft slant back kits used to be made from) and one is a prototype in mil spec PVC vinyl. I'm still figuring out how to sew this to completion. I thought it would be interesting to run the zippers all the way to the C pillar. This makes the entire tailgate and bed accessible. Time will tell if this design is practical. I'm worried about flapping and vibration. Given that the Mk1 and Mk2 frame and covers seem to NEVER flap, I hope I am worrying about nothing. Notably, this design uses only three pieces of material. My current pattern uses 7. Less cutting and less sewing means faster results.
BDGR
Bulldogger
774
Quantico VA
BDGR
Until I have this mounted and outside I won't have a good feeling for whether windows are still practical. Certainly one in the center panel will have a bar running through it. I do like being able to see into the bed from the back though. In my own ride I mounted a rear view mirror too. I'll lose that function if I make the center panel solid PVC. With the HMMWV tailgate as tall as it is, the practicality of seeing behind me is limited anyway. Can't see a compact car at all. (Sorry pal, it's your fault I backed over you, because you should've bought a bigger truck. 'Merica! :LOL:)
Another thought about windows and bed access is to sew zipper panels into the sides. I think I'll do this with the Cordura prototype, as I consider this material expendable anyway. I'm trying to make the PVC desert tan cover sellable because I have someone asking for it for a while.
A zipper side panel will have to be water tight and will need some kind of flaps to keep out wind, I assume. Breton would have made this a heat sealed hidden sipper, like the soft doors, but that process is not feasible for a small home shop like mine, so an still cogitating on what that should look like.
Has anyone some pictures or experience with zipper access in the side of a tarp or bed cover?
BDGR
TXTripod
NE PA
I am loving this new design as an alternative to the stock 4-man soft cargo look. Your new humpy shape in the rear adds a little more fender storage functionality and fits the slant back Humvee look that’s more familiar to most.
FWIW, I wouldn’t miss a window in the rear with my bumper-mounted spare tire. (I also added a center review mirror for DOT inspection, but it’s already pretty useless!) Keep us posted on progress, and great work so far!
Bulldogger
774
Quantico VA
Here is the finished Gen 3 "humpty-back" cover. I am sealing the seams on this one, to see how it performs. I've not had seam leaks reported to any great degree, to any great degree, but wanted to explore it. Will finalize the frame design this week. The existing frame on the assembly jig is pieced together and not entirely symmetric. Once I make measurements and cut an entirely new frame to test, I can finalize the design just as I did with the Mk 2 frame.
Will be a finalized kit soon. The extra wide and extra long zippered center panel is also an experiment. I think the cross bars will control flapping, but am not sure if a 4'Wx5.5'L roll-up center panel is of much use or desirability.
BDGR
Bulldogger
774
Quantico VA
The cover and frame are complete. They look similar to the pictures given, so I’ll wait until I have on-truck photos to share. This will be going out to Texas soon to escape our unusually cold Virginia winter and enjoy some sun.
BDGR
Bulldogger
774
Quantico VA
Here are some field photos of the new prototype mounted on my truck. I need to tweak the forward fitment, but the rest wasn’t bad. This cover will need one more modification and then I can ship it out to my beta tester. The frame seems good. I’m still cogitating on the assembly instructions. It’s a bit fiddly and I want to improve that.
Bulldogger
Bulldogger
774
Quantico VA
Here is a couple pictures of black versions. One is PVC and one is civilian sailcloth. My Facebook page has a lot more “action photos”. I am not allowed to link it here, but if you go to FB and search Madmountain Military you’ll find me.
Bulldogger
774
Quantico VA
I have a black PVC in stock and black sailcloth on the sewing table now.
Bulldogger
Also, to be very clear: the full tailgate width version is a beta prototype and I don't know if I will be offering it yet. I need some field information about how well it holds up first. My Mk2 and Mk2.1 covers are made for the already-tested frame and those are in stock now.
BDGR
TXTripod
NE PA
@Bulldogger We finally got some sunshine this Easter weekend, and I fitted the new soft slant back. Great fitment and a lot of new fasteners I never knew existed! Loads of cargo room and a really cool look without sacrificing any modular flexibility. I can’t wait to give it a spin this week! Thank you for this awesome new option.
Bulldogger
774
Quantico VA
Thanks for posting it! I see I need to manage the folds up front better. Though it may be a simple case of my jig and truck vs yours, especially where the 4-man top meets the back cover. If I fit a cover too tight it might only fit my truck…
I look forward to some field reports!
Please keep us posted.
BDGR
Bulldogger
774
Quantico VA
Made a new milspec heavy duty SSB cover last week. This one goes to northwest Florida. Hoping the customer is happy. I have enough material for two more in this style and trim.
Bulldogger
774
Quantico VA
This is not a slant back but I wanted to share I have set up a cargo cover frame on my building stand. I’m going to see how hard it is to make a cargo cover. I will be making these out of sailcloth or other non-military materials. Since milspec vinyl options already exist, and at milsurp prices, I do not plan to try to compete with their lower costs.
More as it evolves.
Bulldogger
774
Quantico VA
Finished late last night. There are several things I’ll do differently on the next one but this one is serviceable. I can’t compete with milsurp prices on tan or green vinyl, but sailcloth being a specialty fabric I hope to have more business interest.
Debating whether to put this in the classifieds.
Bulldogger
Bulldogger
774
Quantico VA
I forgot to mention I made some stiffeners to go across my cargo cover bows. The strapping is terrible. Since I have everything to make slant back frames I made 5 clamp-on bars to give the bows some help.
