HMMWV accessory AC power
jake-cutter
13
League City, Texas
I am looking for a plug and play inverter type solution to run ac accessories such as a phone charge. I already have an Iris Quite power inverter that plugs into the slave receptacle, it just bothers the passenger side as it goes right by them. I would like to find one like the pics and youtube vid below that can run off of the radio power. Anybody know what type of inverter/power distribution box that is?
https://www.youtube.com/watch?v=SqmeTSDvmHw&t=236s
Wire Fox
158
Indianapolis, Indiana
Well, nobody is forcing you to actually use the slave plug for the Quiet Power system. You can simply open up the housing for the slave plug, unbolt the two leads, slide them out, and then route them into the battery box to be hard wired. ...and then you could mail the unneeded slave plug to me! :grin:
But for completionists' sake, I would like to know what that unit is as well. It looks like it has a few more plugs than is usual, and also looked like it ran off of a radio power cable.
jake-cutter
13
League City, Texas
I found an older version for the M113 pn# 12383862 that has some of the connections, but of course older models. Looks like there were some updates and even contracts out for updated versions as of 2014 for use in an MRAP and up armored HMMWV's. At least its a starting point to finding it as it seems like a nice plug and play option.
