- 3,833
- 3,961
- 113
- Brooklyn, NY
Either your batteries are in parallel or your generator is fried.
Might I suggest posting a picture of your battery setup AND might I suggest investing in a solar type battery tender.
AFAIK, your generator is suspect. Also, if you are running any 12V off of only 1 battery, then you are frying that one battery. You need to return to a factory setup.
When you replace batteries, you need to replace in pairs, especially after a weird situation like this. I also swap batteries every month from front to back, so no one battery gets over-charged in the series hookup.
If it is not one of those things, then find a shamen to remove the voodoo hex and curse.
Electrical issues are torture... I wish you well.
Best,
T
Best,
T
