HMMWV Doesn't Shut Down With Ignition Switch
hawk-aggie
68
College Station, Texas
568 was a left over from the 60A alt days and should have been plugged (capped) off and tied back to the harness.
Agreed. Unfortunately, the last army goober who worked on it, jacked it up. It may have been done on purpose, so they could turn it in for a new truck. In any case, it wasn't a quick find. I just decided to check wiring while I was disconnecting items to see what might be causing the issue. It took some digging. I was losing my patience last week, until Cam at Camotek stepped up and helped me focus.
NDT
7,534
Camp Wood/LC, TX
This still does not make sense. The 60A alternator excite wire is switched from the ignition switch. It would not have 24 volts with the ignition switch off.
hawk-aggie
68
Evidently, it's not controlled by the SRS switch when it's connected directly to a 456 wire, of which there can be multiples. The 456 wires are apparently getting the 24V that also goes to the TSU, Fuel Cutoff, Glow Plugs, Cold Advance Switch, to name a few. When the 568 wire is connected directly to the 456 wire, the 24v supplied through the 456 takes the place of the voltage normally supplied by the excite wire, or so it seems. I can't adequately express what's happening. All I know is that with those two wires connected, the fuel cutoff was not being controlled by the SRS switch and the truck kept running. So far, with those two wires not connected and tied off, the truck is shutting down every time the SRS switch is turned to the STOP position.
