I have a 1986 Hmmwv and it started having pump issues back in September. Pump started making whining noise. I replaced it once and about a week later it started whining. Took it to a diesel shop in town and they replaced it again. Said the pump I installed was done correct just a bad pump. I drove it until about a week ago and during that I noticed if I tried to turn the steering wheel right after I start it it will not move to the right. You literally cannot muscle it any further. I usually have rotate to the left and then right a few time to get it to "unlock". Pump went out last week again and at the same time it blew the hose off nipple as it enters the radiator. I was parked on a hill to pickup my brother and as I was sitting there I felt a nasty vibration in the brake pedal than then it just dropped an inch or so. I could still stop so i new it was something with the hydroboost and not a brake line. Seemed like it had excessive pressure in the system suddenly and blew the line off, but I am just guessing. I put a new pump in a few days ago and drove it 20 miles and the pump is shot again. I notice vibration while braking and jerky power steering. The pump had full oil levels and the system flushed twice. Is this issue more likely caused by a faulty power steering valve controllers? Any help would be appreciated.
Thanks.
Thanks.
