HMMWV gauge panel wiring diagram
js0276
Atkins AR.
What is the wiring diagram numbers for the gauges
Temp?
Fuel?
Batt?
oil pressure?
high beam?
dash lights?
Mogman
8,247
Papalote, TX
Not sure what you are asking for, the wire numbers are on the applicable schematic, there is no schematic for the instruments only, just complete vehicle schematics.
Here is a schematic that the numbers are clear on, as far as the instruments all HMMWVs are about the same.
js0276
Atkins AR.
Not sure what you are asking for, the wire numbers are on the applicable schematic, there is not a schematic for the instruments only, just complete vehicle schematics.
Here is a schematic that the numbers are clear on, as far as the instruments all HMMWVs are about the same, kind of a PITA but the best one I have is too large to post
What are the wire numbers that plug into each gauge?
Temp?
Volts/BATT?
Fuel?
oil pressure?
TOBASH
2,998
Brooklyn, NY
Temp?
Volts/BATT?
Fuel?
oil pressure?
You are now realizing that there are technical manual on this bulletin board that are free. Mogman is strongly implying that you need to go through the technical manuals on your own to search out the circuits
js0276
Atkins AR.
You are now realizing that there are technical manual on this bulletin board that are free and Mogman is strongly implying that you need to go through the technical manuals on your own to search out the circuits
WOW
Lot of good helpers on this site!
Thought maybe someone already had it written down some where
GUESS I WAS WRONG!!
TOBASH
2,998
Brooklyn, NY
WOW
GUESS I WAS WRONG!!
US gobment rote it down for ya’ wit letters an’ pitchers and ebythin’
It’s all there. Seriously. Diagrams too.
Mogman
8,247
Papalote, TX
Why would anyone write it down, it is plain as day on the schematic I posted, in fact they will be pretty much the same numbers on your M151, wire numbers are mostly standard throughout.
We are here to help but not to do all the work for you.
papakb
1,186
San Jose, Ca
All of this is located in the back of the TM 9 2320 280-20-3 manual. If you haven't already downloaded them you should!
Now the REAL QUESTION here is why is the +24V power to the voltmater labeled 567A when it's simply another lead coming off of the 27 line?
