Hmmwv ground harness, upgrade
Natron13
Hopefully this is the right spot for this post, I am looking to start selling hmmwv grounding harnesses that I build for helping with all the ground wire bugs we get and hear about.
The harnesses are constructed of green 6 gauge vinyl coated copper stranded wire with the proper sized terminal connectors to not only join the 4 different length wires but also for the ends for connection. These are still very flexible, durable, and will be less expensive and better quality than the other setups that are sold from other companies. ..........................(some text removed)......................
This is just an idea I’m having to keep me busy and seeing how many people would actually be interested in it. Thank you
TOBASH
3,057
Brooklyn, NY
The harnesses are constructed of green 6 gauge vinyl coated copper stranded wire with the proper sized terminal connectors to not only join the 4 different length wires but also for the ends for connection. These are still very flexible, durable, and will be less expensive and better quality than the other setups that are sold from other companies. I will be selling the harness for $50 with normal setup and $60 if you want all connections heat shrink wrapped. This is just an idea I’m having to keep me busy and seeing how many people would actually be interested in it. Thank you
Perhaps the classified section?
Also I believe this forum allows for surveys. You might want to recreate this thread as a survey.
Good luck to you.
