Hmmwv head question
TOBASH
3,244
Brooklyn, NY
OEM heads are AMG /Detroit Diesel.
N/a heads differ slightly from turbo heads. Turbo heads will not accept n/a manifold. The head bolts attaching the intake manifold to the head come in at different angle. You can identify with long bolts. Just place bolts in the intake manifold holes in the heads and if the angle matches then you have n/a heads.
I would not swap heads. I would swap engines.
IMHO
Tato
Italy
n/a heads differ slightly from turbo heads. Turbo heads will not accept n/a manifold.
IMHO
I found the complete engine but the heads are branded GF
TOBASH
3,244
Brooklyn, NY
Like I said, check the intake manifold bolt hole angles. If the engine already has an n/a manifold then who cares about the GF?
Are you suspecting Chinese knock off heads? If so, buy another block. If the heads are original, then who cares about the stamp?
Tato
Italy
unfortunately I only have photos and a video but I think they are Chinese heads
NDT
6,182
Camp Wood/LC, TX
GEP would have never used old GM heads at manufacture. So unless the engine you are looking at has been rebuilt by someone, it should have GEP sourced heads.
Tato
Italy
QUOTE="NDT, post: 2485513, member: 7671"]
My old block was GM with Diamond branded heads
Tato
Italy
maybe it's the dalton foundry logo that looks like a CF,does anyone know?
NDT
6,182
Camp Wood/LC, TX
How did you know the cylinder was cracked before you disassembled the engine? Oh and the heads in your pictures look made in USA to me.
Tato
Italy
the exhaust started to smoke white and the liquid in the pan disappeared, logically water in the oil
NDT
6,182
Camp Wood/LC, TX
Ha my GM 6.5 has been like this for 6 years, I keep refilling the coolant every time the low coolant light comes on, this is in a Chevrolet 3500 truck. Runs perfect but smokes a little white on start up too.
Tato
Italy
it could also be a damaged head gasket, mine drank 2 liters of fluid in 8 miles. however, from the dipstick you can check, if you have milky oil
TOBASH
3,244
Brooklyn, NY
Time for a new engine and use this one as a boat anchor. If the engine was rare or valuable you could weld and sleeve it, but in this case it is cheaper to just save the internal parts and heads and get a new engine. IMHO. YMMV.
juanprado
2,812
Metairie/La (N'awlins)
Welcome to the madness!
I lived in Rome for a few years as a kid in the 70's. Would love to go visit.
There are some European US surplus dealers and this is a fairly common engine for many years so hopefully you can find one close and reasonable.
Tato
Italy
great! I'm from Viterbo, 50 miles from Rome, if you come to these areas let's meet! I found a good GEP but the prices here are very high for spares
