check the crankshaft pulley bolt is tight. I had it loosen up and almost wore the keyway away.
started fine but blew smoke.... timing was off due to pulley loose side to side, wearing away the keyway on the crankshaft
you may notice the pulley move abnormally, it should be tight.
