Hmmwv power steering squealing help needed
Kswiney
Fort Worth
88 hmmwv power steering staring squealing occasionally now it's constant and steering is very hard. I checked the fluid and its was a little low, so I added some and it helped a bit. I went through the bleeding procedure with a small amount of improvement. Am I missing something? Is the PS pump bad?
Styk33
0 Star General
Sacramento/CA
If it is squealing, that is more likely the belt, meaning the pump is not spinning freely. Adding fluid and bleeding was a good starting point, the next is to check the pump (as you mentioned).
