HMMWV Radiator hose part numbers, can anyone help?
DREDnot
624
Avondale , AZ
Add a signature line to your profile that has the year/model number of your truck.
The part numbers can be found in the -24P TMs
This is out of the earlier truck manual
Coug
4,814
Olympia/WA
M1097R1 6.5 2007
Thanks for your help.
Radiator hoses will be the same for either, but the R1 series is a bit of an oddball (recapitalization program trucks that started out as either 3 or 4 speed and upgraded to heavy suspension). For other parts, if you have a 3 speed use the M1097A1 for parts, if it's 4 speed use the M1097A2 for parts in the manuals.
Mogman
10,581
Papalote, TX
One small caveat to that great advice, if your truck has a GVWR of 10K even if it is a 4 speed it will have 10K (A1) half shafts and brakes.
If it has a GVWR of 10.3K then it is pretty much a straight up A2 truck.
BTW that is a good thing (10K) as the A2 half shafts start around $550 ea. where as you can get the 10K shafts from several parts houses for around $150 ea,
