HMMWV Red Dot A/C Filter Part Number
aghumvee
222
Blairstown,Missouri
Does anyone have the part number for the "air" filter on the red dot a/c unit? My M1043a2 filter is all mossy and nasty from sitting at GP lot getting wet from c pillar removal.
Thank you
aghumvee
222
Blairstown,Missouri
Can someone look at the filter on their red dot unit and post the part number or photo of the little sticker on the filter?
Thank you
Coug
4,823
Olympia/WA
So I took a look at my filter.
There are no numbers on it anywhere. There is no sticker on it anywhere.
Outside of the frame has some arrows for airflow direction, and some words, but nothing to identify a part number for it.
It also doesn't show up in the Red Dot parts catalog under filters (but the R-2400 evaporator isn't there either)
Dimensions are 17-5/8"x5-3/8"x1"
(doing a search with those dimensions doesn't turn up anything for me)
There is always the chance if you send Red Dot a message they might be able/willing to help you. I think I remember hearing good things about their customer service for civilians with military surplus stuff.
hrbergeron
411
Geographical Center of Virginia
This is an old thread, but since I didn't see anyone answer the question, here is what mine says.
RD-2-4132-0
"Washable Filter"
There is different filter models that will fit. I checked my other hmmwv with the red dot system, and it had no label and the screen mesh on both sides, whereas this one only has it on the inside. This one also had a flow direction where the other did not.
