Hmmwv rubber O-ring warped
ANG3CHEAPSHOT
26
California
So I’m replacing my tires and I’ve finally got my run flat back in and the drum back in and I open the package to my new O-ring. Because they were looped in the packaging the have a couple slight bends in them and won’t lay flat on the rim. Does anyone have any tips on how to straighten them out so I can finish putting this thing back together??
mgFray
924
Southern Minnesota
Straighten them out by hand (gently). You might want to set them in the sun for a few minutes...
Then use some 'green slime' (tire fix-a-flat).. put a SMALL amount in the grove, set the o-ring into the grove.. if it isn't holding, add a SMALL amount on top.. between the o-ring, the grove and the green slime it should hold in the grove..
Then use regular (not the locking) nuts to put the two halves together, torque to spec... air it up -- verify it's holding.. then _REMOVE ALL OF THE AIR_ (NEVER remove any of the bolts with air in the tire!), and swap the locking nuts ONE AT A TIME, torque to spec, air it back up and it should be fine.
I did my 4 tires this way (by hand, no power tools) and everything was air tight the first time.. only thing is the green slime will run between the wheel halves, so might drip out.. but this is why you only used a SMALL amount.
ANG3CHEAPSHOT
26
California
got it thanks I’ll try that
mgFray
924
Southern Minnesota
Not sure this adds any actual value to the thread, but this was one of mine halfway through the process. You can see the washers and standard nuts at this point, along with the tire soap on the edge of the tire, and the green slime bottle upper right.
I was just about to air up the tire and verify it was holding in this picture, before swapping all of the lock nuts on.
Mogman
8,401
Papalote, TX
I use Murphy's tire soap, buy it 5 gal at a time.
You can also take a huge tractor tire with a 3" or more gape all the around the bead and make it take air!
If you scoop it up as the tire ejects it you can recover allot of it, will not hurt anything to do with a tire.
GOOD STUFF!!
mgFray
924
Southern Minnesota
GOOD STUFF!!
Don't remember what brand I bought, but I got the smallest bucket I could. I'm pretty sure it'll last the rest of my life!
But this was the first time I'd ever mounted my own tires, and I consider it a success in my case. Even though it did take many many hours to do all 4 tires.
Ajax MD
1,420
Mayo, MD
Hi all, just to piggyback on this-
Can someone please confirm that the RED o-rings are for wheels with a lower load rating that do NOT have the small hole (as seen in the photo above) and that the heavier rated wheels (with the hole) use a BLACK o-ring? Is this true, or internet rumor?
Thanks.
Mogman
8,401
Papalote, TX
Thanks.
I think you have that backwards, according to HPG these are the rims the RED O ring fits.
Mogman
8,401
Papalote, TX
There is no reason to use the earlier wheels unless you want do do a "correct" early restoration as the 12 bolt wheels with the alignment hole and even 24 bolt wheels are abundant and cheap.
Ajax MD
1,420
Mayo, MD
When I bought my truck, it came with the bias tires and wheels on them. I simply bought 12 bolt wheels with M/T's on them and ran them. I have a mix of earlier and later wheels hanging around the house.
The reason I'm going through these machinations is because I discovered a nasty cut in the sidewall of a tire that is just begging for a blowout. I have a good spare but it leaks down so I want to replace the o-ring before installing it on the truck.
Ajax MD
1,420
Mayo, MD
Question:
I know there's a bias tire run-flat and a radial tire run-flat. Is there also a radial tire run-flat that has an integrated spacer or is there always a separate spacer?
If so, how can I identify it?
mgFray
924
Southern Minnesota
AFAIK radials do not have a spacer of any type. It's just a donut with a ridge down the middle. I disassembled by 4 tires on my rig (12-bolt with centering hole), removed the runflats. (Yes there was 'goo' inside the tires between the runflats and the tire.). I could have compressed them and put them into the new tires, but I went with the PVC beadlocks instead.
Retiredwarhorses
3,893
Brentwood, Calif
Question:
the bias ply RF was a magnesium 2 piece, not a great idea, then the 2 piece rubber RF for the early 12 bolt rim, and finally the 1 piece RF we are all most accustomed to seeing, there is also as of recent a new aluminum 2 piece being used in the latest trucks.
86humv
490
Texas
Thanks.
Ajax MD
1,420
Mayo, MD
Grr, I can't break the bead to remove the top half of the wheel. I'm ordering a bread breaker and spoons.
mgFray
924
Southern Minnesota
Do you have an engine hoist? You can use a hoist to separate the rim, and then pull the rim off the bead.
Go about 18:30 into the video to see how to do this. It's how I did all of my rims.
(Note when I did it to my own tires, I used a strap to center the pull in the rim.. worked great for me.)
Ajax MD
1,420
Mayo, MD
I don't have an engine hoist at the moment. I've seen that method.
