HMMWV Sealant
sbob4579
New York
So I just noticed today that there was some sort of sealant or something chipping off on my HMMWV. Could anyone tell me what this sealant is and where I can get this sealant? Thanks! Here is a picture attached below.
Wire Fox
161
Indianapolis, Indiana
I'm going to tune-in to this topic as well. My HMMWV has all of that same sealant chipped off, allowing water to pour in on top of my left foot. I was just going to fill the space with RTV, but if someone knows the right stuff, that's great!
NDT
6,303
Camp Wood/LC, TX
That's some of the atomic body panel glue that AM General's robots squirt on the panel edges before assembly. Who knows what it really is. Avoid silicone as that can mess up future paint jobs.
BKubu
1,127
Gaithersburg, MD
Would welding the seam be a solution? I can see how it might be a problem if you wanted to remove a body panel. But, I bet 99 times of 100 you won't be removing those body panels. Best of all, I think a nice weld will actually be cleaner looking than the factory caulking. Just a thought...
juanprado
2,877
Metairie/La (N'awlins)
It looks like 3m panel bonding adhesive I used to sell when I worked in parts. I also have some chunks that came loose when I pressure washed mine.
Wire Fox
161
I think I could buy into that assessment. Although, the cost of that 2-part adhesive, the applicator, and the mixing tube tells me that it's just not worth it unless I was prepping up for a full-strip restoration. I think I'm going to temporarily use the RTV just to keep some excess water out of the cab and will peel it off later when I go to strip the paint.
Awol
459
MA
Just be careful, silicone is extremely difficult to completely remove. It's an extreme contaminate, and works itself into the metal. Most auto body shops don't allow any silicone products anywhere near cars that are being painted.
Wire Fox
161
Great to know! Haven't uncorked the tubeyet, so you may have saved me some trouble.
gringeltaube
Staff Member
2,472
Montevideo/Uruguay
....I suspect they are some flavor of urethane.
Yes, PU-sealant/adhesive. No silicone at all; 1000 different uses and applications, at least...!
Search for SIKAFLEX 221, here on this site and you'll be surprised in how many threads it was mentioned...
