sandcobra164
- 295
- 83
- Leesburg, GA
Title more or less say's it all. I searched but my primary computer crashed and I can't download anything on a chromebook. My starter is busted up due to the inboard motor bolt snapping. Now the starter is off the truck, we removed the bad bolt but the solenoid is broken away from the nose cone. It's still attached somewhat but the aluminum is busted away. Will a HMMWV Starter work, 6.2 should work but what about 6.5'? I'm not ready to go 12 volt as I still have a Deuce that needs to be slaved off from time to time. I've not counted the teeth on the pinion gear but willing to buy a 12 volt one and change the nose cone and keep the solenoid and the motor on mine if that would work. The HMMWV starter would be cheaper for me but I don't know much about GM Diesel's.
