2deuce
- 147
- 63
- portland, oregon
Does anyone have one of these mounted on your HMMWV and could give a few pics on how it attaches? Can you use it with the folding grille guard?
I needed to see that too
This is the setup that I use - I just bought everything on epay......The other solution is to use the 3/4 feet from the oshkosh square tube tow bar with the tan aluminum biscuits as that is how I think it packaged as a "kit"
Anyone have a picture of how the biscuits are used?The other solution is to use the 3/4 feet from the oshkosh square tube tow bar with the tan aluminum biscuits as that is how I think it packaged as a "kit"
I have a set of those feet with all the pins. PM if interested. MWMULES was selling the biscuits very reasonable.
The picture previously is of the medium round tow bar feet. Not sure if the foot has been modified/bushing as i thought it was a different diameter.
The small pointy hole of the biscuit goes into the black 44lb tow bar. It uses the pin from the tow bar. The foot Y with the wide 1-1/2 pin is on the other side of the flat biscuit. ( pic below the bigger pin is sideways and you don't see the opening). The smaller side of the foot is 3/4 and attaches to the mount on the HMMWVAnyone have a picture of how the biscuits are used?
No biscuits or grinding needed if you have the tow bar you pictured in post #11 , then you do not have to do anything as long as you have the 3/4' feet shown in #3 as they will fit that tow bar without grinding. Grinding of the feet or using biscuits is only needed when using the big Black Ibis Tek 44,000lbDo you have a picture of the feet on the tow bar?
Just want to make sure I do it right.
Yes, and very cheap from kascar 12342373 $4 These are the rear for the airlift bumper when not using tear drop shacklesInformative thread even for those who are sans HMWWV. My question from the outside looking in, are the HMMWV tow shackle anchors available? They look somehwat useful on another project I have.
I really like the one above where you can leave the shackle in place and add the tow bar.Yes, and very cheap from kascar 12342373 $4 These are the rear for the airlift bumper when not using tear drop shackles
https://www.real4wd.com/zedSuite/catalog/partdetail.aspx?PartNo=12342373
Those are fronts. They are available & out there but way more $. Cheapest I think I have seen is $40 each flea bayI really like the one above where you can leave the shackle in place and add the tow bar.
