HMMWV Transfer case
jeremymx26
Brownsville ,PA
The transfer case has an internal differential that allows slip front to rear for road driving in H.
HL locks this differential to send torque to the front and rear equally.
Use only HL when surface is slippery or transfer case damage will result.
2w091
Kentucky
Per the -10 manual HL should be used for deep snow, sand, or mud only. If you drive in HL on pavement or another non-slip surface too long you can throw a short shaft or cause other damage.
NDT
5,870
Camp Wood/LC, TX
To lock the axle differentials you are supposed to perform "brake throttle modulation".
2w091
Kentucky
We had a neighboring agency drive theirs around in HL and throw a short shaft. I put a caution in our pre-use checklist and labeled the actual shifter.
