Shbennett1985
- 28
- 13
- Carthage nc
Good Morning Friends
Hoping someone could share their experience on the following.
2000 M1123
1. Changed transmission filter and fluid when I got it home from Albany. All good for 1,000 miles. Recently it has developed a 1.5 second engagement delay after 60 seconds of running. This is a delay from Park-Drive-Reverse. No delay when it is first started. Sifts fine and no slippage once engaged. Could this be a fluid pick up issue? Wondering if some contaminates have blocked the filter again?
2. Also have DTC 73 Pressure control solenoid circuit error. Not sure if the two are related.
Anyone have experience with either? Thank you!
2000 M1123
