- 7,478
- 10,499
- 113
- Papalote, TX
If it were me and I was sure it was not a jelled fuel issue (I live in S. Texas so probably would never happen down here) the first thing I would do is check the return line which you said you did, if that was clear then I would clean the top of the IP as best I could and remove the return line fitting in the top of the pump, there should be a clear glass ball in there, a check valve, make sure there is not any black trash stuck in it.
Be very careful and CLEAN! do not get any trash in the IP and do not use any pipe sealing tape on it.
Edit, you cannot take that fitting apart, but you should be able to see light coming through the glass ball.
