ETN550
- 9
- 0
- Knoxville, TN
Here is my Pow'r Gard 3KW gen put into a Carver Fuel pump silent housing. As you can see it does not exactly fit! Pretty close though. the base dimensions are 20 x 22. Put way too many hours in this but I will say it is very quiet. It can be placed between 2 people and they can have a normal conversation at normal levels while it is running. I used the belly tank from an 016D. The generator pulls fresh air from the end that sticks out. The engine fan intake and air box pull from a sealed off and insulated chamber that opens to the ground underneath. The hot air is exhausted through the two silver vents on the side. This was the scheme that the Carver pump used and it was very quiet too. The controls are simple for now. Two push pull cables to make the start / stop levers work. Separate preheat and crank momentary switches, and toggle switches to turn on the panel and the new fuel pump. My initial tests indicate that the engine temp is a little hotter but okay and exhaust temp is normal. Gen end is okay. I left the original lift handles on it and added some wheels and 2 feet, each with tiedown loops. I measure fuel level with a dipstick for now.
After I take a break from this one for a while I will proceed to fully disassemble it and sandblast and paint, and add new decals.
