storeman
- 52
- 48
- Mathews County, VA
Not if well vented.Cool, nice work. I just got an MEP002 with the ASK set up on it. Do you think you will have any issues with overheating with your setup?
It is significantly quieter. I still have a few holes to plug. One of the article I read said that a hole the size of 10% of the area lets out 50% of the sound.WoW - Great idea - have bid on these in past - no luck yet but will keep trying as your project looks like a super mod. From the unaltered "baseline" how significant is the noise supression with mod? Thanks for posting lots of pics - Really Neat!!
I just copied what was already in the enclosure. I will continue to take measurements of temperatures using my infrared gun. However, it is now getting colder so I won't have real results until next summer.Based on my experience, the engine cooling fan in the flywheel of air cooled diesels does not move enough air to keep an enclosed unit cool. I suggest you add an additional fan to move air through your enclosure before operating it in warm weather.
The oil temp is a great idea. I'll do the same thing. I spent this weekend cutting in a new access door to be able to get to the dipstick easily. I also insulated the exhaust system. another idea is to mount the primary muffler outside the enclosure to further reduce heat.My experience is with trying to reduce noise in Yanmar L48 and L70 powered stuff. With the flywheel end drawing outside air in through a plywood enclosure, oil temp starts to run away at higher sustained loads when temps are above 80F. An 800 to 1600 CFM fan pulling additional outside air should do the trick. I used a couple surplus 8" 120VAC fans in my plywood box with good results. Of course, openings for fans let more noise out.
If your load is less than 50% with only short spikes at higher loads, you may never need additional cooling. If you run large constant loads such as lights or resistive heaters, you may want to watch oil temps on warmer days.
The Yanmar application manual has oil temp and air flow info.
YANMAR Application Manual LV Series pdf free ebook download from martindiesel.com
I made an oil temp sensor using the dipstick under the muffler. I drilled a small hole through the top and ran a thermocouple down along the dipstick. I then coated it with epoxy using a plastic tube as a mold. Using an old Fluke meter with a thermocouple input let me watch oil temps.
