Homemade Load Bank
pclausen
281
Afton, VA
When load testing during the winter, I do plan to let it heat up my shop building (48 x 30). :)
Looks like my breaker bank will fit nicely in the build in box:
Test fitted the contraption in the enclosure after removing the compressor and coil:
Got 4.5" of clearance from the bottom of the tube and the floor of the enclosure:
I think that will provide enough air flow up thought the heater elements and I don't need to cut out openings in the floor of the outdoor unit, which was a concern I had.
pclausen
281
Afton, VA
Got it done.
Heating element wiring:
Double pole double throw switch with center off position to select 1,800 or 2,700 watt configuration:
Powered on testing with just the fan running:
Video of it in action:
Given how I have it connected to a 20A breaker for testing, I dare not kick on any real load. :)
