Hood hinge orientation
Tinwoodsman
76
Comfort, Texas
I am re-installing the hood on my deuce and I forgot which way the hinges are positioned. I am not sure whether the two prong portion of the hinge is on the cowl or hood side. I have attached a picture on my hinge as currently installed. Would someone please check their deuce and let me know which is the correct installation?
Thanks,
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Just looked at mine, two tabs facing away from the cab on the pass side, two tabs facing the cab on the driver side. Go figure.
RAYZER
59
sanford/florida
took mine off once to clean them up and when I reinstalled them and tightened the bolts with the hood down,they were in a bind when I opened the hood,had to loosen the bolts again to correct the problem.
1,808
When installed you should be able to project an imaginary line through the pivot pins. If one or both are reversed you won't be able to do that. Better yet you should be able to lay a straight edge across the top of them. Bad juju will happen to you hood if you install them incorrectly.
JCKnife
46
Kentucky
From those who have done it: any tips for reaching the nuts up in the firewall to remove the hood hinges?
