thedeliverator
- 0
- 16
- Albuquerque NM
Well, for the past few weeks, I've had an intermittent problem with one of the alternator belts. Periodically when throttling up from idle, something won't catch right, I'll hear a squeal as the belt slips, the GEN2 light will flicker a bit. Not something I was in a terrible hurry to fix, other problems have had precedence, etc, etc.
Now, I've also had problems with the hood release from day one. Sometimes it will pop on the first try, sometimes it's try the handle, pound on the hood, try the handle again, get out the rubber mallet, rinse, repeat.
Flash forward to today when, well, the squealing from the belt stopped... because the belt broke. And, of course, I can't open the hood. I've tried everything short of prying it up that I know of, still won't pop up enough to get to the lever.
So, my question is, what if any tricks are there to getting the hood open? Will unscrewing the hood release handle from the body panel help to take up slack in the cable? Is there I spot I can pry on to get it up? Some voodoo with a coathanger that will unlatch the mechanism?
If I do get it open, how can I make sure this won't happen again?
How true! NOT the ED yet!!
