hooking up 2 heaters
218
Kingman az
Here's the deal. The truck I recently bought has two coolant heaters installed. One under the hood and one in the cab. Only one is currently hooked up, however I have swapped hoses around and they both work well and don't leak. Is there a problem with putting a tee fitting in the hoses so I can run both of them? I am planning on putting them on separate switches for power. Any input would be appreciated.
Thanks
jimm1009
71
Louisville, KY
dual heater system
Unfortunately I have not yet done this but was in the planning stage. One for Defrost / defog only and one for heat only.
If your hoses are in series they may work better than in parallel and I personally think that the system would flow better since it would be a loop rather than being a T.
Here is Louisiana it never really gets cold but there is the ever present danger of too much fogging in the windshield during the rain.
I think that this would work great for you as you need a little more heat where you are.
As long as you don't exceed 80% of your alternator total capacity you should be good to go.
I hope other will chime in on your thread and I'm anxious to read more.
jimm1009
AceHigh
31
Lake City FL
I have a heater and a coolant bypass filter both teed off the engine. The filter is somewhat restrictive and my experience is the heater works great but the filter stays cold if both are on. In other words the coolant will flow where it is easiest to go.
Your plan should work though.
atankersdad
15
Glen Arm Maryland
I would hook them up in series to ensure equal flow. I would put the flow to the cab heater first and then into the one under the hood. You would rather radiat the most heat into the cab verses the engine compartment. Either flow direction will work...How cold does it get in KY?? One fuel fired heater would run you out of that truck...
jdr2710
Colorado Springs, CO
Back when I worked as a plumber doing hot water heat systems we used a thing called a diversion T. Basically it was a T with a restriction to force some of the hot water to flow on the main path and some for the T'd path.
Here are a couple examples:
monoflow T
venturi T
Note you could do the same sort of thing with a couple ball valves to balance the flow. One valve in line with each of the heaters, then fiddle them until they are both heating as you want.
218
Kingman az
I think i'm going to do the series install with it going to the cab heater first. It gets fairly cool down here last week it got down into the high teens at night. also off hand does anyone know what size the line is that goes to the heaters, I would like to pick up a fitting while i'm in town. Thanks for all the advice and I will let ya'll know the results when the job is finished.
dittle
72
Albia, IA
Any thoughts on adding coolant to make up for the amount that the extra heater will hold in its lines?
